×We are trying to create below rules using Automation for JIRA plugin.
1)We want to move the Test Execution issue status to 'Done' based on the execution result for the associated test. We are not able to achieve this since there are no defined conditions in the plugin to make changes to test execution ,associated with a test issue type.
2) Similarly we want to move the status of the Test set to 'DONE' when all the associated Tests are also in Done status.
What link type can we used for different Xray issue types ,associated with each other since these associations are not considered as a 'link' in the plugin.
Hello!
If under the hood, Xray is using jira custom fields then probably automation might help.
If not, then there is no integration of automation with this.
I would suggest to reach out through support portal, so that somebody can take a closer look and see if its doable or not.
Sherry
