I'm not crazy about loading the forms page, using the developer tools, going to the Network tab, then finding 'forms' and then selecting 'Preview'. Especially when you have a huge number of forms, I think it would be easy to get the wrong form.
For me, on a test project where I had just one form, it was pretty easy to line them up and I got the same UUID via both methods:
If you have multiple forms attached to a card, you might need to use list operators to get all the ids.
Trying this out now, and the smart values doesn't seem to work with fields that are using a data connection? The returned value and id for the dropdown are always blank. Same smart value on a static dropdown works.
EDIT: 2025 March 07 - created a support ticket and have confirmed it now works for fields using data connection too!
We’ll soon be removing access to Forms (previously ProForma) data currently stored in entity properties from both Issue properties routes and Project properties routes.
Do we have a plan for when we will remove it? It's crucial that we prepare in advance to transition to the new methods for accessing the form data. Thank you.
32 comments
