Request Types vs. Issue Types: How We Simplified Our JSM Portal
When we first rolled out Jira Service Management (JSM), our portal was cluttered, confusing, and overwhelming for users. The root cause? A misunderstanding of the difference between Request Types and Issue Types.
In this article, I’ll share how we clarified this distinction, redesigned our portal, and created a smoother experience for both customers and agents.
Understanding the Difference
Issue Types
  • Represent the backend structure of a Jira ticket.
  • Examples: Incident, Service Request, Change, Problem.
  • Define workflows, fields, and automation.
Request Types
  • Represent the frontend experience for customers.
  • Examples: “Report a Bug”, “Request Access”, “Ask a Question”.
  • Map to one or more issue types but allow customization of forms and language.
Our Problem
  • Users saw too many confusing options.
  • Similar requests were routed differently.
  • Agents had inconsistent data to work with.
Our Solution
1. Grouped Request Types by Category
  • Created categories like Access, Hardware, Software, and General Help.
  • Each category had 2–3 clear request types.
2. Mapped Request Types to Simplified Issue Types
  • Mapped multiple request types to a single issue type (e.g., “Request Laptop” and “Request Monitor” → Service Request).
  • Reduced issue type complexity for agents.
3. Customized Request Forms
  • Used hidden fields, preset values, and conditional logic.
  • Ensured agents received all necessary info without overwhelming users.
4. Used Automation to Route Requests
  • Based on request type, auto-assigned to the right team.
  • Triggered relevant SLAs and notifications.
Impact
Metric Before Cleanup After Cleanup
Avg. Ticket Resolution 3.8 days 2.1 days
Portal Request Options 25+ 10
User Satisfaction (CSAT) 78% 92%
Tips for Others
  • Start with your users: What language do they use? What do they expect?
  • Limit request types: Less is more.
  • Use forms smartly: Hide complexity behind clean interfaces.
  • Review regularly: What worked last quarter may need tweaking now.
Final Thoughts
Simplifying our JSM portal by properly using request types and issue types was a game-changer. It made the system more intuitive for users and more manageable for agents. If your portal feels cluttered or confusing, this might be the fix you need.
1 comment
Kerli Suve
In my experience, most JSM setups tend to struggle with the same pain points. That’s why I usually recommend starting with as few request types as possible. Once the system is in use, analyze what people are actually requesting on a regular basis and only introduce new request types when there’s a clear recurring need that justifies it.
Like # people like this
