Sign up Log in
Using Cascading Fields with Forms and Assets
This workaround is meant to help users that want to use cascading fields with forms or use a 3+ level cascading custom field type.
So this is an option of the workaround from the features below:
And is meant to help projects where it is necessary to use multiple select options in a field, I used Jira Forms with Assets. In addition, I used as an example a form with the "Country" field in which, depending on the selected country, will open options related to "State" and "City" (all following the selection of each one). This method can be used for other purposes (eg. general and administrative costs).
Important related documentation:
Create or edit a form
Set up the Assets objects custom field
Workaround steps:
  • Create Assets objects schemas
    • Create object schemas for each item that will be used, as well as for each option that will be used on the cascading logic, for my example I used: Countries, States and Cities.
    • It will need to link an object 'Country' to an object 'State' and to an object 'City' as an attribute:
    • Country:
    • State:
    • City
 Remember to mark the option "Allow others to select objects from this schema". For more details about object schemas, please refer to Create an object schema
  • Create Assets objects custom fields
    • Create a custom field (assets) for each option that will be used in the cascading values, I created the field "Country", "State" and "City".
    • It will need to use the Filter issue scope (AQL) to reference the object custom field in the order of your cascading logic. In this example: Country > State > City
      Using the AQL:
      object HAVING inboundReferences(Name = ${customfield_XXXX.label})
      For outbound references:
      object HAVING outboundReferences(Name = ${customfield_XXXX.label})
    • Country field:
    • State field:Screenshot 2023-03-31 at 18.55.46.png
    • City field:Screenshot 2023-03-31 at 18.57.31.png
 Remember to mark the option "Display a default object when this field appears in a customer portal" to the refered field objects. For more details about object schemas, please refer to What is the Assets objects field?
  • Form Settings:
    • Create a form and add an Assets/object field and linked then to the Jira Assets object field:Screenshot 2023-03-31 at 19.09.05.png
This workaround will work as shown in the screen recording below:
13 comments
Bruna Silva
March 31, 2023
Extremely useful! :D
Like Bruno Altenhofen likes this
Charles Trilha
March 31, 2023
Nice Article! ProForma Legend, Bruno!
Wagner Filho
March 31, 2023
Amazing article, Bruno!
Tomislav Tobijas _Koios_
April 1, 2023 edited
I've recently tested this at one of our client's environments and it worked pretty well. The only thing that didn't work is clearing out the second or third-level field when the first-level field is cleared or when the value is changed → we didn't configure the field so that the default value is displayed.
In general, it's a cool workaround, but it's only relevant if you have JSM Premium or Enterprise plan (so when you have an Assets feature available).
Anyway, really cool and useful article there 🙂
Bruno Altenhofen
April 3, 2023
Hey @Tomislav Tobijas _Koios_
Thank you for your feedback! 🙂
Yes, unfortunately, it will always preselect a value that was linked to the Asset object custom field, but you can change it if you have other options, as I show in the screen recording.
Prathiksha
April 3, 2023
This one is super helpful! :D
Apurbo Mandal
April 10, 2023
Perfect learned a lot.
chaitanaya d
Hi sir could make it more details on Cascading fields
with below Example: 2 cascading fields
                                   Profession(parent value)
Private Sector(child value)                  Government Sector(child value)
  1. Software engineer                            1.police officer
  2. Mechanic                                          2.Govenment Officer
  3. Doctor
Adam Gołaszewski
I found a bug that it only displays a Label attribute even if you select more attributes in the Allow search filtering by these attributes in the field context configuration. As per below screenshot even though i have three attributes selected i only get the one that is a label attribute. Not sure if this is raised in Atlassian yet.
Like Rune Rasmussen likes this
Tyler Kosaski
How would I configure AQL of the asset attributes of state and country to enforce this cascading when entering objects in Assets as well?
For example what if there was another object schema containing people where I wanted to track their location.
Like J Conners likes this
Beau Spree June 20, 2024
Hi @Bruno Altenhofen -
Am I right in thinking that we can only have 20 items per drop down?
"The Assets object custom field can be configured to store up to a maximum of 20 objects." - I found this on setting up the asset custom field article.
Please let me know if I am wrong?
Thank you
Matthew Challenger
This is great! Always such insightful articles from you, @Bruno Altenhofen. Thank you!
Rune Rasmussen
March 7, 2025 edited
EDIT:
This can almost be done, it seems.
I'm running into some weirdness in that my "Technical Owner" field is displaying the Label of the object and not the attribute selected.
I'll report this as a bug.
Could this magic also be used to prepopulate other Assets fields with attribute values from the selected object?
Example:
I have an Object called "Jira Cloud".
The Jira Cloud object has an Attribute called "Technical Owner" and that attribute value of "Rune Rasmussen".
So on my Form I would have to Assets Fields.
One to select the Object and one to then Display the specific attribute of the selected Object.
So when, on my Form, I select "Jira Cloud" in the first Assets field then the second Assets field on my form would display the value of the Technical Owner attribute as "Rune Rasmussen".
Upcoming Jira Service Management Events
