Calculate the sum of original estimates of all issue types to an Epic using Automation
69 comments
Alex Koxaras -Relational-
Simon your rule seems ok. I've tested again my own and it's working alright.
I know that this can be a dumb thing to say, but you please check that your task/planung issue type has indeed a value? And when you make sure of that, can you go ahead and refresh the Epic page? It takes a while to update the field with the value.
Simon Huprich
Hey Alex,
All the issue which are part of the epic have a value.
When the rule executes automatically, the value that I added manually was changed to "0m" again. (from 2h to 0m)
Like Jules Cuijpers likes this
Simon, copy and paste the following JSON to a new JSON file and import it as a new rule.
"cloud": true,
"rules": [
"id": 4585207,
"clientKey": "392b6b84-aff8-31f3-bbcf-d4dc4de7f1a3",
"name": "MINE: Sum Original Estimate in Epic",
"state": "ENABLED",
"description": null,
"authorAccountId": "5f9fb7c1c2e5390077abf628",
"actor": {
"type": "ACCOUNT_ID",
"value": "557058:f58131cb-b67d-43c7-b30d-6b58d40bd077"
"created": 1639726658951,
"updated": 1661844588245,
"trigger": {
"id": "159519843",
"component": "TRIGGER",
"parentId": null,
"conditionParentId": null,
"schemaVersion": 2,
"type": "jira.issue.field.changed",
"value": {
"changeType": "ANY_CHANGE",
"fields": [
"value": "timetracking",
"type": "field"
"value": "worklog",
"type": "field"
"actions": [
"edit"
"children": [],
"conditions": [],
"connectionId": null
"components": [
"id": "159519844",
"component": "CONDITION",
"parentId": null,
"schemaVersion": 3,
"type": "jira.issue.condition",
"value": {
"selectedField": {
"type": "ID",
"value": "issuetype"
"selectedFieldType": "issuetype",
"comparison": "ONE_OF",
"compareValue": {
"type": "ID",
"modifier": null,
"value": "[\"10002\",\"10004\",\"10001\"]",
"multiValue": true,
"source": null
"children": [],
"conditions": [],
"id": "159519845",
"component": "BRANCH",
"parentId": null,
"schemaVersion": 1,
"type": "jira.issue.related",
"value": {
"relatedType": "epic",
"jql": "",
"linkTypes": [],
"onlyUpdatedIssues": false,
"similarityLimit": 40,
"compareValue": 0
"children": [
"id": "159519846",
"component": "ACTION",
"parentId": "159519845",
"schemaVersion": 1,
"type": "jira.lookup.issues",
"value": {
"id": "_customsmartvalue_id_1639726474486",
"name": {
"type": "FREE",
"value": "lookupIssues"
"type": "JQL",
"query": {
"type": "SMART",
"value": "\"Epic Link\" = {{issue.key}}"
"lazy": false
"children": [],
"conditions": [],
"id": "159519847",
"schemaVersion": 10,
"type": "jira.issue.edit",
"value": {
"operations": [],
"advancedFields": "{\n \"fields\": {\n \"timetracking\": {\n \"originalEstimate\" : \"{{lookupIssues.Original Estimate.sum .divide(60)}}\",\n \"remainingEstimate\" : \"{{lookupIssues.Remaining Estimate.sum .divide(60)}}\"\n }\n }\n}",
"sendNotifications": false
"children": [],
"conditions": [],
"conditions": [],
"canOtherRuleTrigger": false,
"notifyOnError": "FIRSTERROR",
"projects": [
"projectId": "10005",
"projectTypeKey": "software"
"labels": [],
"tags": [
"id": 13693947,
"tagType": "IS_RULE_UPDATED",
"tagValue": "true"
"ruleScope": {
"resources": [
"ari:cloud:jira:f1b53191-2545-46a7-841f-975e03eb0b9f:project/10005"
"writeAccessType": "UNRESTRICTED",
"collaborators": []
If the above rule fail to update the epic, then most likely something else is happening.
Try it and let me know.
Like Deleted user likes this
Andreea Cetateanu
September 6, 2022
Hi @Alex Koxaras -Relational- ,
After a lengthy search about how to create a rule that adds up Original estimate and Time remaining from a Story to an Epic, your post was a breath of fresh air. However, it seems that it is working only for Original estimates field, for me this rule is not working on of Time remaining field (the hours are not 'removed' at an Epic level when I log hours on a Story level).
I use an additional add on for time tracking (Tempo) is this the issue? or is there another issue?
P.S.: I only started to work with Jira Rules today.
Your answer is much appreciated!
Best regards,
Andreea
Hi @Andreea Cetateanu and welcome to the community!
So what you are telling me is that:
  • You have implemented the rule
  • The rule runs properly and add the Original Estimate
  • But it doesn't do the same for the Remaining Estimate
For all your issues you use tempo to log your work. Correct?
Andreea Cetateanu
September 6, 2022
That's correct!
Can you try to log time on an issue using the native method and see what's the reaction of the rule? Does it work properly?
Nishanth
October 10, 2022
I having the issue in my automation rule. I tried to calculate Due date based on post function.
I attached my post function screenshot below
Based on function I created the automation rule. I added the smart value for this numeric expression as "{{issue.duedate}} - {{issue.timeoriginalestimate}} / {{8*60}}" in Due date . But when i execute this rule its not adding the due date field in the sub task.
I having doubt my smart value is correct or not. Please someone could help me for this issue
Nishanth
@Nishanth hi and welcome to the community,
I believe that you should create a Jira question for this issue you are having. If you have any question regarding the automation I presented here, feel free to ask!
Thomas Christof
October 11, 2022
Thanks for providing your setup.
Your trigger events are "Time tracking" and "Work logged". I am wondering what is the difference between them.
Anyhow, I have noticed they are not triggering the event when someone updates "Remaining Estimates" on a task or sub-task. So I thought to create a rule for calculating the aggregated values triggered by changes of remaining estimate. Unfortunately, Remaining Estimate is not in the list of fields for the "Field value changed" trigger.
Any idea how to set up a trigger for rolling up updates of remaining estimate?
Jen Doherty
Thank you for the detailed article, it's really appreciated! However unfortunately I'm having some issues with this automation. I have recreated it exactly as written except only for story type issues, but the automation seems to be cumulatively adding to the epic's timetracking fields instead of replacing them.
For example, if I have an epic with no children and 0m original estimate and create a child story with 1h original estimate, the epic updates to 1h also - so far so good. But if I add a second child also with 1h estimate, the epic now updates to 3h - the original field (1h) plus the first child again (1h) plus the second child (1h).
The rule is successfully running with no issues in the audit log, and looking at the Atlassian documentation an update *should* do a set and replace the original value.
Any suggestions on how this could be fixed?
Rule details:
Jen Doherty
After some further experimenting, I found the issue. Using "Epic Link" = {{issue.key}} did not work for me because our epic links are not just the issue key, they are text fields. So I was using (as you can see in the screenshot) parentEpic = {{issue. Key}} instead, which was also finding the epic itself. changing the lookup issues query to "parentEpic = {{issue. Key}} AND issuetype != Epic" has solved my issue.
Like 3 people like this
Neeraj Patil November 21, 2022
Hey @Alex Koxaras -Relational- , Thank you for this.
I'm looking for the same with Sub-tasks to Story.
Instead of Log work and Remaining work fields, I'm planning to use Original Estimate field?
But as I see, Original Estimate Field is not showing up in the fields dropped down.
Any thoughts there?
BTW, I had used a similar one for the Story Points, which is working smoothly.
Neeraj
@Neeraj Patil on standard issue types there is a checkbox under time spent/remaining estimate to include subtasks. This works for the two fore mentioned fields but not for the original estimate. What fields do you want to sum up?
Neeraj Patil November 22, 2022
@Alex Koxaras -Relational- I want my team to update the Original Estimate field to be updated for the Sub-tasks and that is reflected in the Story.
@Neeraj Patil this is fairly easy to change in the existing rule. You have to tweak a couple of things:
Like 2 people like this
@Thomas Christof sorry for the late reply. I tried changing the remaining estimate and my rule triggers just fine.
Omer Gurtemel
December 28, 2022 edited
Thanks for sharing. It is the only one that I could achieve somehow a result!
However, it works on some specific cases:
  • Once a task is created as a child under the Epic, original estimate value of the task is added to the original estimate & time spent of the Epic --> OK
  • Once a task is updated by entering time spent in terms of hours,  remaining time of the Epic is updated accordingly --> OK
  • Once a task is updated by entering time spent in terms of others (weeks/days/minutes) , remaining time of the Epic is NOT updated accordingly --> NOK
  • Once a subtask is created under the task of the Epic, although remaining of task is updated accordingly, this update has no impact on the remaining time of the Epic --> NOK
Here is my automation details:
Jules Cuijpers January 15, 2023 edited
Hi Alex,
Thank you for this post.
Unfortunately I experience the same problem as @Simon Huprich
The automation rule succeeds, but the Epic won't sum up the Original Estimate values from work items.
I also imported the JSON from @Alex Koxaras _Cententia, but the problem still exists.
Do you maybe have some other tips?
Thanks in advance!
January 16, 2023
Hi @Jules Cuijpers -- Welcome to the Atlassian Community!
I note in the image you posted that there is an extra space after the sum function in the JSON.  Have you tried removing that?
Jules Cuijpers January 17, 2023
@Bill Sheboy
Thanks for the tip. I removed the space and the rule succeeds but the epics still stays on 0m.
@Jules Cuijpers
It seems that no issues can be found during the lookup. Double check your JQL
Jules Cuijpers January 17, 2023 edited
Thanks guys. I just found the solution. This works:
Yevhen Matsiuk
April 27, 2023 edited
@Alex Koxaras -Relational- Hi, thx for this post.
When the rule executes automatically, the value that I added manually was changed to "0m" again.image.png image.png
Laurent May 4, 2023
Thanks for that great job !
But I can't run that rule because of an error :
Could you help me ?
