Autoclose parent when subtasks are closed
Tim
Hi
we have the Workflow extenstion in Jira and I want to chose to post transition action as described here
https://innovalog.atlassian.net/wiki/spaces/JMWEC/pages/94142542/Transition+parent+issue
But I don't have an option to close the parent items on subtask closure.
There are the only ones I see
 Assign to Current UserAssigns the issue to the current user if the current user has the 'Assignable User' permission.
 Assign to Lead DeveloperAssigns the issue to the project/component lead developer
 Assign to ReporterAssigns the issue to the reporter
 Clear Field ValueClear value of a given field.
 Copy Value From Other FieldCopies the value of one field to another, either within the same issue or from parent to sub-task.
 Create Crucible Review Workflow FunctionCreates a Crucible review for all unreviewed code for this issue
 Set issue security level based on user's project roleSet the issue's Security Level to the specified level if the current user is in a specified Project Role.
 Trigger a WebhookIf this post-function is executed, Jira will post the issue content in JSON format to the URL specified.
 Update Issue Custom FieldUpdates an issue custom field to a given value.
 Update Issue FieldUpdates a simple issue field to a given value.
How can I choose the update parent if it is not in the list?
Radhika Vijji _Innovalog_
May 11, 2020
Hi Tim,
Look at the Manage add-ons page for JMWE app and you check whether all the modules are enabled or not. If not, and if possible try a reinstall of the app (you will not loose any data)
Radhika
John Funk
May 7, 2020
Hi Tim,
It does not appear that the JMWE app is installed. All of the options available through that app appear like this:
Transition parent issue (JMWE app)
Where (JMWE app) appears after each option. And there are a LOT.
So I would say with certainly that the App has not fully gotten installed on your instance.
Tim
Hi John, thank you for the reply.
It did work on the simplified workflow. Is it by default installed then for simplified workflows but not for custom workflows?
John Funk
May 11, 2020
I would think it would be on ALL workflows. Not sure there is even a way to differentiate between them on the install.
You probably need to contact JMWE support for assistance. Once you have a resolution, can you come back here and update the thread?
Register Now
