  • Community
  • Q&A
  • Jira
  • Questions
  • Automating Jira Cloud Project Creation with a Board Having 3 Statuses per Column (Without Add-ons)
Deepak Rai
I am trying to automate the creation of Jira Cloud projects where each project's board contains multiple columns, and each column has exactly three statuses. I want to achieve this using Jira's REST API or with any other automation steps without relying on any external add-ons.
What I need Help with:
  • Is there any way to automate board column configuration (assigning statuses to columns) via API in Jira Cloud?
  • Can this be done without using external marketplace add-ons?
  • Are there any workarounds or alternative approaches to achieve this automation?
Thanks in advance.
March 5, 2025
Hi @Deepak Rai
When I last checked, there was no REST API support for configuring a board, only to create a new board.  Here is the suggestion to add such configuration capability: https://jira.atlassian.com/browse/JSWCLOUD-20535
Deepak Rai
Thank you @Bill Sheboy and @Marc - Devoteam for response.
Marc - Devoteam
March 5, 2025
Hi @Deepak Rai
As @Bill Sheboy mentions you can't configure a board.
But if you have a template project based on the setup you require, you could copy that projects board to the newly created project by use of the API.
Or at least it was possible, using the API endpoint /rest/greenhopper/1.0/rapidview/{source-board id}/copy
Deepak Rai
@Marc - Devoteam Looks like this copy endpoint is depricated. I am not able to use this getting an 405 error.
Marc - Devoteam
March 7, 2025
Hi @Deepak Rai
Then this endpoint has been removed, I knew it was related to the old rest API version.
So unfortunate this can't be used anymore.
So there are no rest api options anymore and so currently no workarounds.
Deepak Rai
Thank you @Marc - Devoteam
Like Marc - Devoteam likes this
FREE
