Automation rule to create the sub task and assign the status based on Parent
Syamala Uggina May 8, 2020
Dear All,
Need your inputs.
Here comes my Automation Requirement.
When I create a sub task to already existing story and if the status of the story is "To do, "In Progress" or "Ready for testing"
Then my created sub task should have the " To do" status by default instead of Backlog.
If Story is in backlog the sub task created too should have the same status.
Did any one tried this rule?
Hana Kučerová
Hi @Syamala Uggina ,
I think you can achieve this by creating automation rule, that will transition the Sub-task from "Backlog" to "To do" status, if the parent (story) is in one of the statuses "To do", "In Progress" or "Ready for testing".
So, basically, all the Sub-tasks will be always created to the same status, but under some circumstances will be automatically transitioned to the other status.
John Leonard
October 11, 2021
I have a number of tasks that get created in different projects which each need a different status set to them when they are created. Is there a way to do that?
Register now
