Automation to divide two custom numeric fields
Dionei Piazza
I need to get the result of divide two custom fields I created in Jira. I'm using automation with smart values. This is the syntax:
{{issue.customfield_10136}} / {{issue.customfield_10135}}
With this sintaxe I get this error message in the log:
Could not convert the field value to a number. Please ensure the value is a number, math expression or smart-value that can be converted into a number.
         Desvio Estimativa: ( / 6.0)
No fields or field values to edit for issues (could be due to some field values not existing in a given project):
TES-46
Any help appreciated!
Robert Wen_Cprime_
Do you have default values if the custom fields aren't set?  e.g. issue.customfield_10136 should be 0 if not set and issue.customfield_10135 should be 1 if not set.
Dionei Piazza
Wow! It works now!
Thank you @Robert Wen_Cprime_
Haley Soltau
March 8, 2024
I know this is old but as I was looking for this myself, I thought I would come back and share the answer.
This is what you need to put into your smart value calculation
{{#=}}{{issue.customfield_10136}} / {{issue.customfield_10135}}{{/}}
The begin and end symbols are what lest Jira know you actual want it to compute.
Everything can be found here...
https://confluence.atlassian.com/automation/jira-smart-values-math-expressions-993924866.html
Harsh
May 13, 2024 edited
Hi @Haley Soltau
II am using the same thing but unfortunately this does not work for me. I am using JIRA Server/DC. And I am performing the action on EDIT, i.e. after creation
Could you please help me out here. Thanks a lot.
I get the following error
Error rendering smart-values when executing this rule:
Missing parameter(s) for operator /: 25 /
Where 25 is the value for number field A
and I am dividing by 5 which is the value for number field B.
I am expecting a result of 5 here
Thanks in advance.
Natalia Matsyuk September 28, 2023
A bit unrelated math function, but I found this video helpful: https://www.youtube.com/watch?v=Pi7_CInMTQc&ab_channel=ApetechTechTutorials
Robert Wen_Cprime_
Yeah, @Alex Ortiz is good with his videos from Apetech Tutorials.
Fabian Lim
Hi @Dionei Piazza
Can you share what the type of customfields are the ones you are using for the calculations including the one with the formula?
Dionei Piazza
Hi @Fabian Lim
All Number fields.
Fabian Lim
Ok, never seen this error message, but can you confirm that the customfield does not have a context that blocks it from the TES project? Also make sure that the field is added to the screens of the issue type.
Dionei Piazza
The field appears in the screen.
If I set manual values in the automation it works. For example 4 / 2. In this case, it work fine!
But when I use the sentence {{issue.customfield_10136}} / {{issue.customfield_10135}}, it doesn't work.
I've try this way {{issue.customfield_10136.divide(issue.customfield_10135)}},
this way {{issue.customfield_10136.divide(issue.customfield_10135).floor}}, but it doesn't work...
Michael Aglas
what about?
{{issue.customfield_10136.asNumber.divide(issue.customfield_10135.asNumber)}}
