I'm using Scriptrunner to populate a calculated field. If for some reason I need to clear any one of the fields used to make the calculation, I need the calculated field to become null. I'm using this code to calculate the field:
def input1CfId = 'customfield_12326'
def input2CfId = 'customfield_12328'
def input3CfId = 'customfield_12329'
def outputCfId = 'customfield_12330'
def projectKey = "CT"
if (issue == null || issue.fields.project.key != projectKey) {
logger.info("Wrong Project ${issue.fields.project.key}")
return
def input1 = issue.fields[input1CfId] as Integer
def input2 = issue.fields[input2CfId] as Integer
def input3 = issue.fields[input3CfId] as java.lang.Float
if (input1 == null || input2 == null || input3 == null) {
logger.info("Calculation using ${input1}, ${input2}, and ${input3} was not possible")
return
def output = input1 * input2 / input3
if (output == (issue.fields[outputCfId] as Integer)) {
logger.info("already been updated")
return
put("/rest/api/2/issue/${issue.key}")
//.queryString("overrideScreenSecurity", Boolean.TRUE)
.header("Content-Type", "application/json")
.body([
fields:[
(outputCfId): output
.asString()
I tried adding this in line 21 but it didn't work:
def output = '0'
Any thoughts about what I could be doing differently here are appreciated!
Your line 21 won't work because the script never gets there - you're terminating it by doing the same test on line 16. Try putting your output = 0 in there instead of the return.
@Nic Brough -Adaptavist-thanks for the help here, I'm now getting a different error in the logs after changing the code to this:
return
def input1 = issue.fields[input1CfId] as java.lang.Float
def input2 = issue.fields[input2CfId] as java.lang.Float
def output = '0'
if (output == (issue.fields[outputCfId] as java.lang.Float)) {
return
.body([
fields:[
.asString()
The error is:
CorrelationId: e04179ed-c172-494d-8415-158ea95bb19a RUN Script identifier: 0c16371a-c617-4cc6-aec8-c2df4ebdbe85 com.adaptavist.sr.cloud.events.WebhookExecution (jira:issue_updated webhook fired for issue CT-371) Script name: Calculate RICE Score CT Took: 454ms Logs: 2021-03-03 14:24:59.118 INFO - Calculation using 1.0, null, and null was not possible 2021-03-03 14:24:59.198 ERROR - Ambiguous method overloading for method java.lang.Float#multiply. Cannot resolve which method to invoke for [null] due to overlapping prototypes between: [class java.lang.Character] [class java.lang.Number] on line 22 2021-03-03 14:24:59.277 ERROR - Class: com.adaptavist.sr.cloud.events.WebhookExecution, Config: null
I'm not sure how to resolve this. Any ideas?
Have you tried return null instead of return?
Hi @Tuncay Senturk _Snapbytes_ , when I change lines 16-19 of the code above to this:
return null
I get this in the logs:
CorrelationId: d3c45b3a-4f71-497a-917f-b925711b12af RUN Script identifier: 0c16371a-c617-4cc6-aec8-c2df4ebdbe85 com.adaptavist.sr.cloud.events.WebhookExecution (jira:issue_updated webhook fired for issue CT-371) Script name: Calculate RICE Score CT Took: 316ms Logs: 2021-03-02 20:50:16.260 INFO - Calculation using 2, null, and null was not possible
Any thoughts?
It seems that the code worked well.
If the snippet is the custom field code, then returning null would clear the field's content.
Register now
