my custom field Select List (cascading) type does not appear in automation. I need it to create a record to Jira Software.
does Select List(cascading) still not supported? is there another way to do it?
Hi @Mar Angelo
This can be done in the More Options section of the Create/Clone/Edit issue actions:
"update": {
"CUSTOMFIELD": [
"set": {
"value": "{{triggerIssue.fields.CUSTOMFIELD.value}}",
"child": {
"value": "{{triggerIssue.fields.CUSTOMFIELD.child.value}}"
You would replace "CUSTOMFIELD" with your custom field name
Hope this helps
@Mar Angelo is your query is solved by using this or still you are facing an issue in Automation
Hello @Mar Angelo ,
Try steps mentioned in this Document--> https://support.atlassian.com/jira/kb/set-value-for-cascading-field-with-jira-automation/
Hi @Mar Angelo
You can use the values below under Additional fields, which is available under More options in the automation
Value of the parent:
{{issue.fields.Cascade.value}}
Value of the child:
{{issue.fields.Cascade.child.value}}
