Get notification on new Issue on sprint or Product Backlog
Jos Pellegrom June 2, 2022
is it possible to get a notification when a new Issue is created on the sprint or Product Backlog?
Jos
Yanty Ghani [ServiceRocket]
June 3, 2022
Hi @Jos Pellegrom ,
Perhaps you can use automation to send email notification when an issue is added to a sprint. For example, this is an automation when the issue is added to an active sprint:
You can remove the condition "If issue matches JQL" if you want the email notification when the issue is added to a sprint.
Hope that helps.
FREE
Learn more
