How can i use ZQL(Zephyr query language) fields in JIRA?
Sopan Sagorkar
I want to use following fields in JIRA for searching test cases.
  • component
  • creationDate
  • cycleName
  • executedBy
  • execution
  • executionDate
  • executionStatus
  • fixVersion
  • issue
  • priority
  • project
    But there are only JQL specific fields present so how can I use ZQL fields?
shiva pandey
@Sopan Sagorkar
you can use ZQL references(fields) by search test executions.
you can find this option in Tests --> Search Test Execution.
Here you can write ZQL query and get the output accordingly.
Shiva Pandey
mattv
November 20, 2018
Does not exist
Like • Philippe Aboulin likes this
4 votes
Manish Tiwari
January 19, 2018
this is pity two useful tools but they can't talk to each other via jql or zql, utter rubbish.
Joel
January 24, 2020 edited
Absolutely Agreed! Utter rubbish. This plugin gets a lousy review on this notion. You cant do any kind of metrics on the test issues from a jira dash. The purpose of Jira is to provide transparency across all projects within. This plugin INTENTIONALLY BLOCKADES THIS!? What the heck? Zephyr's functionality is impressive but its as if they have purposely designed the plugin to fail at sharing and providing transparency.
Like • 5 people like this
Kamil
July 9, 2020
is problem solved?
can we somehow use Zephyr fields in Jira dashboards?
jposluns August 24, 2020
???? yes please someone answer this (+5 years later I would hope there is something)
Udo Brand
July 9, 2015
According to Emilys (Zephyr) answer (https://answers.atlassian.com/questions/276873) you can't mix JQL and ZQL. So it is not possible.
Vamshi Korde January 31, 2020
Is this still not available or is there a workaround?
Sopan Sagorkar
@Nic Brough [Adaptavist] and @Jobin Kuruvilla [Go2Group] can you please help us.
