How to add a Linked issues blocks via automation?
Ram Freedman December 2, 2024 edited
How are you all?
I want to create an automation that when a new issue is created will check:
  • If the issue.components.name = something then add a Linked issues blocks to a specific issue.
  • If not then to check if the issue.components.name = something2 then to add a Linked issues blocks to another specific issue.
  • If not then do nothing.
When creating the automation and the first IF I can see that I can choose between "Trigger Issue" or "Most recently created issue" - but there is no way to set  a start value or an existing issue link etc:
My goal is to select if we need to add a lined issue as bloks and then add it like this:
How can I do it?
Ram
3 votes
Florian Bonniec
Hi @Ram Freedman
You should be able to input the issue key directly instead of "Trigger Issue"
Regards
Hi @Florian Bonniec
Thanks.
I don't see any way to do it.
This is what I see when I select "Trigger Issue":
And if I click on next this is what I see:
Sorry - my bad.
I now see that I can type there and replace the text
Florian Bonniec
You just have to write it where Tigger Issue is wrote. It looks like it's a select list but in fact you can input whatever you want in it.
