×Hi,
i would like to write a rule which will be set customfield to value of "CurrentUser" after IssueCommented Event. (something like this -> customfield_10604=CurrentUser)
How can i make this because this return an error?
Best Regard, Jakub
How about using $authcontext.loggedInUser.name ? Won't that work? It should expand all things in standard velocity context, see https://developer.atlassian.com/jiradev/jira-architecture/web-fragments/velocity-contexts
Hi MateJ,
We think it'd be useful if the ability to set the the currentUser() or the event author to a custom field is supported. Is it something going to be supported in the near future?
Best regards.
Hi Matej,
thanks for your response.
It doesn`t work.
Is it even possible to set dynamic variable in JIRA Automation Plugin rule?
You're right, I've checked the code and it doesn't provide the full Velocity context, only very limited subset - issue info (like key, summary etc) and customfield values. Due to that it's currently not possible however with a little bit of coding skills you can extend the EditIssueAction and implement this.
Hi, thanks for your response.
but what about "Work Logged on Issue" event? I would like to create rule in JIRA Automation Plugin when somebody "Work Log on Issue" and then rule will set customfield to value="CurrentUser".
I won`t using postfunction in workflows.
You can write post function, after issue commented you have to set customfield value to current user, you may look customfield and usermanager classes.
Learn more
