How to make Jira Automation send email to more than 1 google groups?
Zaur Suleymanov
I am setting Jira Automation rule to send out email upon each version release and faced with the problem that email is sent but never received when "To:" field contains more than 1 google group email address.
When there is only 1 group email and some other regular email addresses, everything is fine.
Is it a bug on Jira Automation?
Alexander Pappert
November 5, 2020
you should open a vendor ticket
Kilian Müller
August 24, 2021
@Zaur Suleymanov I experience a similiar problem, I have a google group which includes two other groups and it seems there is no email received at all. Did you raise a ticket or found a solution?
Zaur Suleymanov
@Kilian Müller I did not raise a ticket. I had to type in all email addresses manually asap to make this rule working.
Kilian Müller
August 25, 2021
Thanks for your answer! Thats not good, but probably I will do it also.
Shanaz Vakil
October 10, 2024 edited
Hi
I am also facing this issue if I add more than 1 google group Jira automation only sends the email to participants of one group ...apart from listing the emails individually is there another solution? also is there a ticket for this?
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
