How to show a custom field on an issue that is not populated
Danielle Cantrell
Hello,  I need to show a customer field on the issues screen even when it is not populated.  How do I configure the field to do that?
Nic Brough -Adaptavist-
August 10, 2020
You can't do this on Cloud, it is done by code, there's no configuration for it.
Best you can do is to set a default, so that people will tend not to leave the field blank, but this does mean you'll end up with a lot of junk data lying around.
August 10, 2020
Hi @Danielle Cantrell
There are a couple of open suggestions to add this idea, which you may view and vote for:
Choose whether or not to hide empty custom fields from issue views
https://jira.atlassian.com/browse/JRACLOUD-2997
Option to show or hide empty Epic name and Sprints fields at the issue view screen.
https://jira.atlassian.com/browse/JSWCLOUD-16615
Best regards,
