I switch phone need to disable 2FA and add to the new phone
Tony Nguyen November 21, 2020
I have a new phone. It won't let me disable my 2FA on the disabled 2FA link.  I will need to register for the new phone.  What do I do now?
Tony N.
Victoria Grigson
Has there been any resolution to this? I'm having the same issue. The error message is:
"Something went wrong
Refresh the page and try again. If this keeps happening, let us know using the link below."
Brant Schroeder
Tony,
  Welcome to the Atlassian Community.
Do you have your emergency recovery key?  You will need to use that if you can no longer access your old phone.  If you have your old phone you can connect it to WiFi and you should be able to use the app to 2FA.  https://confluence.atlassian.com/cloud/two-step-verification-976161185.html#:~:text=Disable%20two%2Dstep%20verification,-If%20you%20disable&text=You%20won't%20see%20this,click%20Disable%20two%2Dstep%20verification.
If you've lost your recovery key, see our issues with your account section or contact Atlassian Support to get back into your account.
I do have an old phone but I wanted to switch my 2FA to my new phone since I won't be using my old phone.  When I click on disable two-step verification.  The error popup said something is wrong. It won't allow me to disable it Screen Shot 2020-11-21 at 10.00.40 PM.png so I can enable and scan the new 2FA from my new phone.
Daniel Ebers
November 22, 2020
One last idea that comes to my mind is to see if a different browser also brings up an error message when trying to disable 2FA or to wait a few hours if there has been a system error on cloud probably.
As you do not have some sort of log files, unfortunately nor do we have, best option like Brant mentioned would be to raise a support request with Atlassian support.
Tony Nguyen November 23, 2020 edited
This issue still the same for Chrome and Safari using a mac. How do I open a support request ticket?
Tony N.
Daniel Ebers
November 23, 2020
You can contact support using this link:
https://support.atlassian.com/contact/#/
I cannot open the ticket.  It goes back to this community link?
Daniel Ebers
November 23, 2020
That should only be the case for the free plan.
Are you on a free plan?
I am on using this email for the company's Jira board.  Maybe it's a free plan? What should I do now to remove the current 2FA and add to the new phone?
Daniel Ebers
November 23, 2020
Speak to your local IT support or if not given the one who pays for the site. They can open a support request. Normally this is stated like this on the bottom of that page.
