Is there a built in field that I can use in the filters and get count of all comments in a specified
Satish Agnal December 6, 2023
Need to build a dashboard to track tickets that do not have a comment from relevant teams in the last 24 hours
Adrien Low _ServiceRocket_
Hello @Satish Agnal ,
This is not available out of the box.
Something you can consider is using automation to calculate the number of comments and inserting them into a number field.
The steps in summary are as below:-
  1. Create a new custom field of type Number Field named Number of Comments
  2. Configure an automation to populate the Number of Comments custom field whenever a comment is added
  3. Add the newly created custom fields to your dashboards/filters
An example of the automation configuration is as below:-
You can also add in additional conditions for when a comment is deleted instead.
However, you will have to take your product plan into consideration as there are limits to the number of automation that you can execute on a monthly basis.
Hope this helps.
Regards.
Read the story
