It's possible to create more labels filters on dashboard
Dumitru Darii October 29, 2021
Hi, in the next image is described the problem and the possible solution:
This can be solved by filters, but it is more convenient to do it as in the example above.
Trudy Claspill
Hello @Dumitru Darii
Welcome to the community.
It looks like you are using a Team Managed project. Is that correct? It will say at the bottom of the navigation pane on the left.
If that is correct, then it is not possible to add a filter for a second Labels-type field to your board.
There is a change request to support adding Quick Filters to Team Managed project boards:
https://jira.atlassian.com/browse/JSWCLOUD-17446
Dumitru Darii November 1, 2021
@Trudy Claspill Thanks for the details!
