JIRA Cloud - Filter Subscription Fields Defaulted
Jonathan Zschau June 3, 2020
We're running on a JIRA Cloud instance and just noticed that a filter subscription that has been running fine for months has just switched to displaying the default fields instead of the filter-specific fields we defined when creating the filter & filter subscription.
Has there been an update that introduced a bug or has anyone else seen this happen to their filter subscriptions?
Thanks in advance.
Jonathan Zschau June 9, 2020
Fix rolling out today. Our reports/filters are now functioning properly again.
John Funk
June 9, 2020
Great! Thanks for the update!
Jonathan Zschau June 8, 2020
Hi Everyone:
The last update I've received from JIRA support was this AM indicating that a fix was in the works, but might not get deployed today (USA Eastern Time Zone) due to the responsible team being located in Sydney. Hopefully this is the case and we'll see a fix in the next day or so.
John Funk
June 3, 2020
Hi Jonathan,
It is very easy for filters to get changed with realizing it. I would just update the filter to be sure it is using the right columns you want.
Thanks for the quick response. That's what I originally thought so I modified the filter, saved, reverted and re-saved it as sometimes I've noticed the same. Re-ran the subscription and it's still showing ALL of the default fields, not the fields specific to the filter. Looking at the filter itself and it shows the correct filter-specific columns, but when the subscription runs it comes with all default fields in the email.
Troubleshooting this a bit more. Created a new filter and tried adding/removing/saving/re-saving filter columns/ changing my default columns and the subscription email report is behaving just as if the Filter specific fields do not exist.
This just started today, so I'm thinking this could be related to an update that might have gone through with Cloud.
John Funk
June 3, 2020
Sounds like something weird is definitely going on. I would go ahead and open a support ticket with Atlassian.
https://support.atlassian.com/contact/#/
Thank you, submitted.
Like • John Funk likes this
John Funk
June 3, 2020
Please come back here and update the thread once you get it all worked out. Thanks!
Jonathan Zschau June 4, 2020
Just a small update. They looked into it today and informed me it had always behaved this way and that filter subscriptions always use the user's default columns, not the filter-specific ones. That's just not correct as I have over a year's worth of custom filter subscriptions in my inbox from a variety of weekly and daily subscriptions, each with their own filter-specific columns.
This change definitely happened sometime between June 2, 2020 and June 3, 2020.
Before June 3, 2020 every filter subscription email contained whatever columns were set for the filter subscribed too.
On/After June 3, 2020 every filter subscription will now only email a report with whatever columns the receiving user has set as their default columns.
Brian DaRosa
June 6, 2020
Agreed I’m having the same issue. This is definitely some update or regression issue and it needs to be corrected. Do you have an update on the fix?
John Funk
June 7, 2020
Just found out that this is a known bug that has recently appeared. You can follow the status and add that it affects your team using this link:
https://jira.atlassian.com/browse/JRACLOUD-74554
You should both do that.  :-)
Like • Trudy Claspill likes this
Trudy Claspill
June 8, 2020
Thank you all for your persistence on this. I also noticed this problem, starting today, and found your post.
atlassian, dance, gamification, badge, razzle dazzle, team '25 anaheim
Earn a one-day badge today and do the Atlazzle Dazzle! 🕺
Today only! Share what you’re the most excited about for Team ‘25 or just dance out the beginning of a new quarter with us.
Comment the post
