Jira FORMS compatible with any SD addon
Eduard Diez
May 8, 2023
Hello community
Do you know of any add-on or application similar to Refined that allows further customization of the landing page so that is compatible with Jira Forms and allows to have a friendlier service desk?
Christopher Skoropada _Appsvio_
May 8, 2023 edited
Hi @Eduard Diez
There are two groups of apps to customize the portal:
  1.  Refined and Theme are about changing the look&feel of the portal, but none of them support Forms.
  2. Feature Bundle and other apps that adds features like Edit Requests, Announcement Banners, or Fields View. They work well with existing Forms, but none of them currently have any integration. This will probably change when REST API to Forms is released.
Olha Yevdokymova_SaaSJet
May 8, 2023 edited
Hello, @Eduard Diez
Our team has developed an addon called Smart Jira Forms that can be a great solution for sharing forms for example, on your website or landing page. With this addon, customers can easily submit forms wherever they need to, and the form fields are fully customizable to meet your specific requirements.
Smart Jira Forms provides the same functionality as Service Desk forms and even more, including the ability to create Jira issues after form submission. This feature is available in Jira Service Desk, Jira Software and Jira Work Management as well, allowing you to easily manage issues across different projects.
The addon's conditional logic feature helps to simplify longer forms and make them more user-friendly for customers to complete. Additionally, our new feature called "Destination Issue Fields" allows you to auto-populate Jira issue fields based on form fields, which reduces manual efforts and streamlines the process.
Overall, Smart Jira Forms is an excellent solution for those who need to share forms externally and receive results in Jira. You can view the results inside Jira issues, inside the addon, or export them to a CSV file for further analysis.
Hope this will help!
Aditya Verma
May 8, 2023
Hi @Eduard Diez ,
The one I can think of is Extension for Jira Service Management.
Aditya
Get Certified! ✍️
