Move parent issue to inprogress , when the first subtask is started
Anil Kumar July 7, 2022
Our workflow is Backlog, open ,inprogress,inreview,test ,close
The automation rule should monitor issues all the time.if the issues is in an open sprint , it should not monitor issues in closed sprins. nor in future sprints nor in the backlog without any sprint.
For each issue the automation finds,it should verify if the parent task is in one of these status."Backlog or Open"
If this is true, the rule should move on but if the parent issue is in any other status ,then the automation should stop.
after that ,the automation should move that parent task ( Previously in backlog/ open) to " INPROGESS"
1. parent task goes into inprogress when the first subtask is in progress.
2.parent task into review when the last subtask is inreview , remaining subtask are already inreview or close
3. Parent task goes to "test "when the last subtask goes to "test", all the subtasks are already in "test" or "close"
John Funk
Hey @Anil Kumar  - Did you ever get this solved?
Anil Kumar July 8, 2022
Parent goes to inprogress when first subtask started.PNG parent goes to inreview when all are in inreview or test or close.PNG
Jack Brickey
@Anil Kumar , do you have a rule in place now but it is falling short? If so can you share that info it would be great.
I have created the rule . Parent is taking subtask status.it is working fine. I want the rule as I mentioned above.
Jack Brickey
Please share a screenshot of what you have so far.
Hi @Jack Brickey ,
I have created the rules for below ,PFA images .
For 3rd condition  :Parent task goes to "test "when the last subtask goes to "test", all the subtasks are already in "test" or "close"
What would be the condition ?
Appreciate your help
Anil
Jack Brickey
I think what you are looking for is the IF: Sub-tasks match Status = Test. I found the following post that does a good job of breaking down your requirements.
How-do-I-automatically-trigger-a-status-change-on-a-parent-issue
FREE
atlassian, team ’25 europe, early bird extension, conference discount, barcelona, hybrid event, AI teamwork, early bird pass, digital access, collaboration conference, atlassian events, register now, developer conference
1 week left to save on your Team '25 Europe pass
Still thinking about joining us for Team '25 Europe? Early bird has been extended for just one week! Now’s the time to lock in your lowest rate. Use code TEU25COMM-20 to save 20% at checkout. Hurry, this only lasts for 1 more week.
Learn more
