Person is not visible in issue
Ulrich Holzhey April 29, 2020
Hi all,
I have the problem to see related persons in my issue. I create an group.In this group I have to persons. This group is connected to my project.
But when i will connect the user, I didn't see the.
Any suggestions ?
Uli
Elad Ben-Noam
Hi @Ulrich Holzhey ,
I'm not sure if I understood the problem correctly: you have a project with issues and even when you added the user to the project users, the user still can't see the issues.
(Assuming that you work on a classic project and not a NextGen project)
If that's the case, you should check the permission scheme in the project settings and see who has "browse project" permission.
If this is not the problem, you might have "issue security" defined on the project and you need to check who has permission for the specific issue security.
or maybe I got you all wrong.
Register now
