Populate names in Requestor dropdown
Bhaveesha Khatri January 5, 2023
hi all,
I have a team based project in JIRA, i cant figure out how to populate names in Requestor field dropdown. These will be names who  do not have access to JIRA board but they are names of business individuals who will send these issues and will receive email notifications when issue is created.
can someone please guide me?
Ste Wright
Hi @Bhaveesha Khatri
Can I clarify the need with a few questions?
  • Is this a Team-managed Project?
  • Is this a Jira Project, or a Jira Service Management Project?
  • What type of field is the "Requestor" field?
  • You mention these are Business Individuals without Board access, but will send/create issues and receive email notifications - how will they access the Project if it's not a JSM Project?
Just in case this is a Jira Service Management Project - I'd recommend checking out:
Ste
Bhaveesha Khatri January 9, 2023
hi Ste,
  • Is this a Team-managed Project? - Yes
  • Is this a Jira Project, or a Jira Service Management Project? - Yes
  • What type of field is the "Requestor" field?- drop down similar to Assignee field
  • You mention these are Business Individuals without Board access, but will send/create issues and receive email notifications - how will they access the Project if it's not a JSM Project? - They dont have access to project but only send issues which are logged in their name. I am not sure if they will get  email notifications in this case.
To clarify, i moved the issues from 2-3 boards into a single board. Earlier i was able to see business names in dropdown ( they didnt have access to board earlier too). After moving to new board i dont see their names populated unless they are provided access to the board.
Ste Wright
In a Team-managed Project, the users will need some level of access to create Issues - see how permissions work in this help page
Is that what you mean by "Send Issues"?
I would try modifying the access permissions to the Project first, and see if this changes who is available in the Requestor field.
Ste
Bhaveesha Khatri January 10, 2023
thanks Ste,
Business does not have any access to JIRA but I would record issues from them with their name on Requestor field. Wondering if there is a way to see their name on Requestor field dropdown without them having access to JIRA?
Seems like it worked in old team based project from which i moved.
Ste Wright
January 10, 2023 edited
What type of field is the "Requestor" field - both in your current Project, and the old Project?
You can locate the field type as a Project Admin:
  1. Go to Project Settings > Issue Types
  2. Select the relevant Issue Type from the left-hand menu
  3. Compare the icon next to the field's name, to the list on the right-hand side - to find the field's type
I tested this in a Team-managed Project.
I created a People field, and tried to enter users into it who were...
  1. Active (Site/Product Access)
  2. Active (Site Access) - i.e no product access, so not consuming a licence
  3. Customers of Jira Service Management
  4. Inactive (No Site Access)
I found I could locate and set a user in the field if they were in 1, 2 or 3 above - i.e either active users (with or without product access), or a JSM customer. Are your business users in any of these states?
Note: The People field is not a drop-down list, even though it looks like one when the pop-up comes up. It's a search bar which shows filtered results as a list - so you need to begin entering a user's details into it before they'll come up as an option.
If this does not work, the reason I asked about what type of field is in the old Project is that it might be a Dropdown field, which has had the business users added as actual options.
If that is the case, you'd need to recreate the field inclusive of its options in the new Project.
Let us know if this helps!
Ste
