Quote for the Zephyr plugin procurement for 200 JIRA users
Kutagulla Sukumar December 17, 2020
Hi Team,
If we wanted to procure Zephyr plugin for JIRA, please guide us steps on how to procure and quote for the same.(Currently we have JIRA subscription for 200 users).
Looking forward for quicker response.
Sukumar
Kris G _Alacriz_
December 17, 2020
@Kutagulla Sukumar ,
You can do that from your my.atlassian.com account.
After you login (someone in your company should have credentials, typically the technical contact), go to Orders -> New order or quote -> Quote -> Click on Atlassian Marketplace under Apps at the bottom of the page.
This will take you to a page where you can search for the app you need. Select the app and then choose Cloud as your deployment type. Click on 'Add it'. It then takes you to the next page that has all the Cloud sites that you have subscribed to.
Choose the one you want the app to be installed and take it from there.
I hope that helps.
best,
Kris
Thanks Chris, will proceed accordingly.
