Script Post-Function has No such property error
Jessy Li September 3, 2014
I used to get this code worked but now it breaks
and have error message like this:
2014-09-04 17:07:35,846 http-bio-8080-exec-24 ERROR QA1 1027x947457x2 i3kw56 10.1.247.38 /secure/QuickCreateIssue.jspa [groovy.canned.utils.ConditionUtils] javax.script.ScriptException: groovy.lang.MissingPropertyException: No such property: value for class: com.atlassian.jira.user.DelegatingApplicationUser
Possible solutions: name
for the condition:
cfValues['Solution Provider(SBM)']?.value != null
for the addtional code:
import com.atlassian.jira.ComponentManager;
import org.apache.log4j.Category
 * The template script for setting the assignee from a custom user picker
 * Make sure the user chosen is assignable.
def Category log = Category.getInstance("com.onresolve.jira.groovy.PostFunction");
log.setLevel(org.apache.log4j.Level.DEBUG);
def issueManager = ComponentAccessor.getIssueManager();
ComponentManager componentManager = ComponentManager.getInstance();
def customFieldManager = componentManager.getCustomFieldManager();
def cf = customFieldManager.getCustomFieldObjectByName("Solution Provider(SBM)");
if (cf == null) {
    log.error("No custom field-Solution ProviderSBM found");
    return;
def user = issue.getCustomFieldValue(cf);
if (user != null) {
    def user2 = user.getDirectoryUser();
    log.error("Setting assignee to: " + user2.getName());
    log.error("Issue type : " + issue.getClass().getName());
    issue.setAssignee(user2);
    issue.store();
JamieA
September 4, 2014
Seems like Solution Provider (SBM) is a user custom field, whereas you are treating it like a select list. Maybe someone changed the type?
To check it's not null you should just do:
Jessy Li September 8, 2014
hi, Jamie, Thank you for reviewing. I find the RC. I use the transition in the script post function which did not have 'only assignee condition' before. And I have the condition so the script post function transition failed.
