how can i set the value for some fields (custom or standard) using the mail handler named "Create a new issue or add a comment to an existing issue"?
For example: to set Parent ID of a Subtask.
Should the sender insert some tags in the subject of the email?
@Reply Test Group The delivered product does not allow you to do this. Documentation can be found here: https://support.atlassian.com/jira-cloud-administration/docs/create-issues-and-comments-from-email/
I believe that the app JEMH does https://marketplace.atlassian.com/apps/4832/enterprise-mail-handler-for-jira-jemh?hosting=cloud&tab=overview
Register now
