Tab panel 'com.atlassian.jira.jira-projects-plugin:summary-panel' failed to render
Priyanka Karguppikar February 12, 2019
Kindly give me a solution to this error. This error occurs when I click on overview-> Summary.
Jira Version : 6.4.6
As suggested by Atlassian the permissions of the directories are same as below.
sudo chown -R jira:jira /var/atlassian/application-data/jira
sudo chown -R jira:jira /opt/atlassian/jira/logs
sudo chown -R jira:jira /opt/atlassian/jira/temp
sudo chown -R jira:jira /opt/atlassian/jira/work
chmod -R u=rwx,g=rx,o=rx /var/atlassian/application-data/jira
chmod -R u=rwx,g=rx,o=rx /opt/atlassian/jira/logs
chmod -R u=rwx,g=rx,o=rx /opt/atlassian/jira/temp
chmod -R u=rwx,g=rx,o=rx /opt/atlassian/jira/work
Kindly help.
Andy Heinzer
February 25, 2019
I'm guessing you're taking those steps because you're following along to the KB Tab panel 'com.atlassian.jira.jira-projects-plugin:summary-panel' failed to render.
However it is unclear to me if you're actually seeing the error in the atlassian-jira.log / catalina.out of
Caused by: java.io.IOException: Permission denied
 at java.io.UnixFileSystem.createFileExclusively(Native Method)
 at java.io.File.createTempFile(Unknown Source)
 at com.atlassian.jira.charts.jfreechart.ChartHelper.getChartTempFile(ChartHelper.java:164)
Caused by: java.io.IOException: No such file or directory
 at java.io.File.createNewFile(File.java:1006)
 at java.io.File.createTempFile(File.java:1989)
As cited in the KB.  Are you seeing these still after making those filesystem permission changes?
Are you running Jira with a separate user with the account name 'jira'?
Is there perhaps some other error appearing in the logs when this happens?
Read the story
