We have Jira that can not reach Marketplace. Firewall is open for that
Ralf Thmas
We have Jira that can not reach Marketplace. Firewall is open for that.
Is there any Setting i have to do ?
Greets
Ralf
John Funk
Hi Ralf,
Can you get to the site directly without going through your Jira connection?
https://marketplace.atlassian.com/
Nic Brough -Adaptavist-
April 13, 2021
To test this as closely as you can to the server, try logging into the Jira server and running the connection on that.
If, for example, you're on a Unix-like system, a simple "wget https://marketplace.atlassian.com" will give you a decent error message you can use to chase down why you can't connect.
Like • Deleted user likes this
Ralf Thmas
ah ok. With get it is not resolving
April 14, 2021
Ok, "not resolving" suggests that your server is using a DNS server that is not providing the right information, or DNS is not set up on the server at all.
To get further towards the root of that problem, what does nslookup marketplace.atlassian.com tell us?  It should feed back one of three responses - "dns server does not have an entry for it", "dns server is not responding" or "no dns configured on this server"
Ralf Thmas
where can i set DNS for Jira ?
Ralf Thmas
/etc/resolv.conf is teh correct DNS . Do i have to change in Jira somewhere ?
April 14, 2021
No, this is not a Jira issue, there's nothing to configure in Jira.
Rather than just guess from a settings file that looks right, please could you do the actual test and get the error message?  Your resolv.conf might well be fine and it's something else, but we can't start to fix it without knowing where the problem is.
What does nslookup marketplace.atlassian.com tell us?
