I am using Jira Core hosted in the cloud. I have Jira Administrator global access. This question began as a separate question "Why can't I create a subtask from the view issue screen?" found here:
I had set a Checkboxes custom field called "Department" as required for the subtask. Once I made "Department" optional, I was able to create a subtask. However, when creating the subtask, I want to be able to set certain fields such as Assignee, Due Date, and Department. The way it is currently, when the subtask is created it is automatically assigned to the Project Lead, and I am not given the option to set any custom fields without clicking on and viewing the subtask. Is there a way to set these values upon creation of the subtask? In other words, there is no creation screen that appears for the subtask. I can only populate the Summary field on the view/edit issue screen of the parent issue. Currently, both tasks and subtasks share the same create issue screen and view/edit issue screen. Any and all help is appreciated.
Why don't you create a separate "create screen" for your subtask and put all the fields and custom fields you want to set in it?
Besides you have to deactivate the assignment of issues to the project lead because if not, Jira will automatically assigne your subtask to the project lead although you have specified an assignee in your create screen.
if you need some help in assigning screens to operations (create/edit/view) you can go through this documentation.
I have created a new screen and screen scheme for subtask issue types and set it as the default for create, view, and edit operations. However, this screen still does not appear when a subtask is created.
This is what I see in step-by-step screen shots:
Step 1:
Step 2:
Step 3:
Step 4:
Step 5:
I am sure there is a simple explanation as to why the desired create subtask screen is not appearing at the desired time, but I cannot figure out for the life of me why.
I am having the same issue - any updates?
