Will data be retained when reconfiguring a single selection field to a multi-selection field?
Steve Hooczko
I would like to reconfigure a field with a single selection drop-down to a multi selection field, where several selections from a drop-down list can be made.
When reconfiguring, will the single selection data already in the tickets be carried over to the reconfigured field? I.E., appear as a selection in the multi-selection? For example:
SINGLE SELECTION DATA = 1
RE-CONFIGURED FIELD TO MULIT-SELECTION = 1  (can then add more selections)
Mikael Sandberg
Once a field has been created you cannot change the field type, so you would have to create a new field.
John Funk
Hi Steve,
There is no way to convert a custom field type. You have to create a brand new field and then you can copy the data from the original field to the new field using an automation rule.
Steve Hooczko
July 8, 2023 edited
What would the automation rule be?
Will the rule copy the old data for all tickets in the project to the new field?
Like John Funk likes this
John Funk
Sure, here is an example. When you create the Scheduled trigger, put in a JQL query like Project = ABC for the project that you are updating.
atlassian, jira product discovery learning path, product discovery training, idea prioritization, align stakeholders, discovery to delivery, product collaboration, atlassian learning, dev process, roadmap planning, insight capture, team alignment
Elevate Your Skills with Jira Product Discovery!
Unlock your potential and learn how to use Jira Product Discovery to your advantage. You’ll have the expertise to revolutionize ideas and insights, roadmapping, engage and align teams and stakeholders, and deliver the best solutions—faster. Enroll today!
Start Learning
