copy field X value A to field Y value
Maurice Stassen
How can i copy a field value using an automation rule with "More options" "Additional Fields" ?
I want to set the value of the field "Account" (tempo field) to the same vale as the Jira custom field "Company Code".
I tried this:
  "update": {
    "Account": [
        "set": {"value": "issue.Company Code"}
But this gives me an error:
Action details:
Edit issue
Error editing issuesWNG-1109 (Can not deserialize instance of java.lang.Long out of START_OBJECT token at [Source: N/A; line: -1, column: -1] (io.tempo.jira__account))
November 25, 2020
Hi @Maurice Stassen
You appear to be missing the curly brackets around the smart value for your field.  Please try this one for your JSON.
    "fields": {
        "Account": {{issue.Company Code}}
Here is the documentation on using the advanced editing with JSON to give you more ideas:
https://support.atlassian.com/jira-software-cloud/docs/advanced-field-editing-json/
Also, if you are unsure about the names of the smart value for your fields, you can try this technique to identify them:
https://support.atlassian.com/jira-software-cloud/docs/find-the-smart-value-for-a-field/
Best regards,
