how to create a mask for custom fields
Rodrigo diaz October 30, 2023
hi community
I want to make a mask for a custom field with the objective that the user sees one value and then gives me another.
greetings
Valerie Knapp
Hi @Rodrigo diaz , thanks for your question.
Please can you give an example of what you hope to achieve?
It should be possible with automation, for example, on the creation of an issue to transform a custom field value entered by a user into another custom field value.
I always recommend that people take a look at the Jira automation template library, I found a rule that you could amend and test to see if you can get your desired outcome -
https://www.atlassian.com/software/jira/automation-template-library#/rule/1357059
Please take a look and give us your feedback if this helps you.
Cheers
Praveen V October 30, 2023
I have achieved something similar using Structure and Automation. Your end users can see the custom field as " Masked Field Name" in the structure and it will always point to the custom field behind it.
If you expect your end users to change the value of the field, ensure they have right access level to edit via structure.
Also the custom field must be managable via structure and available on EPIC or Story template.
