jira ui kit and custom ui
Ankit kharola
Hi i wanted to know if its possible to use come of the components form ui kit in my forge app which is using custom ui to create the page
4 votes
Kai Krause
February 9, 2025
Hi and welcome !,
in my opinion you cant use a uikit component in an custom ui page. But you can use the components from atlaskit in an custom ui app. The form iis here as example Form - Examples - Components - Atlassian Design System
BR
Kai
Mel Paisley
February 11, 2025
Hi @Ankit kharola
It's not possible to use UI Kit components in a Custom UI app, however you could create a UI Kit app, then use the Frame component to build your own custom component to use within it.
Mel
