On my workflow, I have the possibility to ESCALATE any ticket at any time. We used to have this button on OLD & NEW view.
But recently we do not see it anymore on NEW view. I suspect that NEW view enhancement changed something but not sure.
new view
If I can see it on OLD view, it confirms that the Workflow is ok
Below some screenshot to show the difference. If someone has a clue? thanks
Hi Caroline,
Yes, the New Jira Issue View does not have buttons for transitions. You see the transitions in the dropdown for the status.
Thanks a lot John
Hi Carolina,
If you swich to old version are you able to see the Transition Button?
State of Product 2026: your pulse check on product development today. We asked 1000+ real teams how they’re feeling–and they had a lot to say.
Get the report
