×We have an issue that is open for a while with a complex workflow. For our team one field is very important on this issue and we wan’t to see if it is changed.
Any way that we can search this change or notify peaople about it directly?
Hi Orlin,
You can use automation for this, send email to particular users when filed value changes.
I hope this snap will help you.
Geethanjali
great!
can you please accept the answer.
Geethanjali
Hi @Orlin,
With our Issue History+ app you can easily see flag the changes affecting this field to differentiate it from other changes in the history!
You can also search changes easily with expressions, see changes highlighted visually for easy identification or share important changes with any user to inform them immediately.
