Unable to set the system date using JIRA automation
Garret Zhang
I am trying to set some Date field in JIRA via the automation during issue creation, but getting the following error message:
Error Message:
"Unknown fields set during create, they may be unavailable for the project/type. Check your custom field configuration. Fields ignored -
Target Lab Entry Date (customfield_10053), Target Lab Exit Date (customfield_10152)"
Automation rule:
Variable:
{{LabEntryDate}} = {{now.format("MM/dd/yyyy")}}
{{LabExitDate}} = {{now.plusBusinessDays(3).format("MM/dd/yyyy")}}
Create a New:
In the "Create a New" task steps I set the dates to the above variables:
"Target Lab Entry Date" set to {{LabEntryDate}}
"Target Lab Exit Date" set to {{LabExitDate}}
Audit Log:
I also verified in the log work that the two dates field work and got the following result in audit log:
Trigger
Garret triggered the rule
Log Action
Log
01/19/2024
Log Action
Log
01/24/2024
What am I missing here?
Garret
Walter Buggenhout
Hi @Garret Zhang,
Can you verify if these fields are present on the create issue screen used in your project (check project settings > issues > screens; and for the Design intake issue type, check the screen associated with the create issue operation).
Fields that are not on that screen cannot be set.
Hope this helps!
Garret Zhang
January 22, 2024 edited
@Walter Buggenhout Thanks for this! Fixed! :)
The field in the form is called "Target Lab date (Entry)", however, there was another custom field called: Target Lab entry date. Looks like I was inputting the wrong field.
Thanks a ton!
