Sign up Log in
Can I sort my JQL query by Workflow statuses as they appear in a Workflow?
Gregory Kremer
Hi everybody,
Does anyone know if it is possible to sort JQL query by Workflow statuses in order of them appearing in a Workflow. For example, I have a Workflow that looks like this:
To Do -> Analyzing -> In Progress -> In Review -> Done
                                      Rejected <- All
I'd like to sort my query to list all issues in a same order:
1. To Do. 2. Analyzing. 3. In Progress. 4. In Review. 5. Done. 6. Rejected.
I'd greatly appreciate any info on this subject.
Trudy Claspill
January 18, 2023
Hello @Gregory Kremer
Are you working with issues in a Team Managed project or a Company Managed project? While viewing the project look at the bottom of the navigation pane on the left to find that information.
If you are working with a Company Managed project then the sorting of issues by Status will be based on the ordering of those statuses globally, which is defined under Settings > Issues > Statuses
https://<yourUrl>/secure/admin/ViewStatuses.jspa
This ordering is applied globally, so if you change the ordering here it will affect all Company Managed projects.
Gregory Kremer
@Trudy Claspill As always, Trudy to the rescue. Thank you so much. Appreciate it.
Kendall Totten
August 3, 2023 edited
Unfortunately this does not work. Clicking the arrows next to statuses results in no changes in the ordering for some statuses. Why is this?
Trudy Claspill
August 3, 2023
Hello @Kendall Totten
Clicking the errors is supposed to help you reorder the statuses.
I personally have experienced issues where clicking the arrows next to some statuses did not seem to move them. In my case this occurred with statuses near the bottom of the list. I had posted about that here that you might find helpful:
https://community.atlassian.com/t5/Jira-questions/JIRA-Admin-JIRA-Status-Sort-can-t-reorder-statuses-to-pull-last/qaq-p/1213549
An Atlassian Team member did respond to help me troubleshoot the issue. However when I did try it again a few days later the problem did not recur.
Somebody recently added a comment on that post about "hidden" statuses. I've not done anything to try to verify what they posted.
