Custom field not visible by default on create issue screen
Martin Vali
February 18, 2022 edited
Custom field not visible by default on create issue screen - So it's not visible to other users
Why it is a problem? Other users don't know it is there
I need guidance, how to make fields visible by default, not by selecting them in "show all fields"
Patrick BIGONNET February 18, 2022
To see all the fields of the screen when you create an issue, you must select "All Fields" in the combo box.
Otherwise you see only the fields you choose
Martin Vali
Thanks for reply
But how other users understand, that there are more fields there.
I want to choose, which fields users see by default
Patrick BIGONNET February 25, 2022 edited
As an administrator, you can't act on this combo_box, it's an end-user choice.
It's an interface's parameter for the user on which he can act to reduce his visibility on the screen's fields when he works on a ticket.
Each user can see the fields he wants.
If the field is required, it cannot be hidden.
You need to explain this feature to your users
Martin Vali
It's strange, that I can not select the fields I want them to see by default
Like • 2 people like this
