Is there a way to customize which fields are shown for the swimlane, when grouping items in a board by Stories?
It would be helpful to display the Epic field for the parent task, so it's visually clear which Epic it is part of. Right now, you can only see type, issue id, status, number of sub-tasks, and summary.
There is no way to do this currently. There are many related suggestions to add this feature. Here are some of them, which you can review and vote for if you wish.
Best regards,
