The interpretation of the Resolution attribute in the graph for values EMPTY and Unresolved is confusing.
Both JQL:
has the same result 201 rows.
JIRA replace the EMPTY value with Unresolved in JQL, but it does not do the same in graph interpretation and data export.
Hot to get 58 rows with JQL.
Hi petr.rihak@uniqa.cz and welcome to the community! By default a "null" resolution is Unresolved. So, in this case, you've created a new custom resolution of "Unresolved". Therefore, you're seeing the duplicate branding. Recommend that you rename your custom "Unresolved" resolution to something else.
