How do we dump sprint data in bulk so we analyze the data rather than api call?
Danisse
Trudy Claspill
Hello @Danisse
Are you trying to extract data for a single sprint or multiple sprints?
What data specifically are you trying to extract?
You can export data from issues in bulk from the Advanced Issue Search screen.
Danisse
We are currently visualizing our data via Quicksight so we're dumping the files being fetched via API on an S3
Trudy Claspill
I'm not familiar with Quicksight.
I'm afraid that answer doesn't tell me what data you are extracting from Jira. Did you construct the data extraction or is Quicksight pull data from Jira on its own?
