How to bulk rename jira projects using groovy script
Abhishek Rawat August 23, 2020 edited
I am trying to bulk rename multiple jira projects. I have a list of current and the new name in a sheet. I am using the following script and it runs perfectly.
I do not know how to run it in a loop so that it picks each item from the old project name column of the excel and updates it with the name in new column in excel.
Here is the code that I am using:
import com.atlassian.jira.project.UpdateProjectParameters
import org.apache.log4j.Level
import org.apache.log4j.Logger
def projectManager = ComponentAccessor.getProjectManager()
def project = projectManager.getProjectObjByName("Old project name")
if(project) {
def updateProjectParameters = UpdateProjectParameters.forProject(project.id).name("New project name")
projectManager.updateProject(updateProjectParameters)
else {
log.debug("Oops, project is unavailable")
2 accepted
Abhishek Rawat September 3, 2020
Also, based on the code,
I created a single groovy script
that can rename multiple projects by uploading a csv with old and new project names.
Hope this helps anyone who is blocked with the same issue.
Cheers!
Ravi Sagar _Sparxsys_
August 23, 2020
Hi @Abhishek Rawat
Let me try to help.
  • Convert your Excel into a csv file and then read the csv file in your script.
  • Iterate over the list of projects. Check this code.
  • Create a method to do the renaming using the code.
Ravi
Thanks a lot @Ravi Sagar _Sparxsys_ in fact my initial script is based on your you tube tutorials. Kudos for creating such helpful content.
