How to get a date AND time field in the next gen project card fields
Dietrich Lehr
On our current legacy project, we have a date/time field as shown in the screenshot. This is all in a single card field. How do we get this same ability in the next gen cards?
Ste Wright
Hi @Dietrich Lehr
You can add a custom field to an issue type in Next-Gen - to do this:
  1. Go to Project Settings > Issue Types
  2. Select the appropriate issue type from the left-hand menu
  3. Choose the field type "Time Stamp" from the right-hand create a field menu
  4. Create it and press Save Changes
You can use this field to set date/time within the same field. You will have to create this per issue type at this stage.
This puts the field on the issue - if you're looking to put this on the card view on the board this isn't possible yet!
Ste
