Hello Eitan,
By the tags added to your question, you are using JIRA Software application, right?
For JIRA software, you can use workflow conditions to determine the users that can transition the issue forward in a specific status.
Please, check the documentation below to know how you can configure this scenario:
- How to create manager approval for multiple departments in a workflow
P.S: The steps above are specified for JIRA Server, however, I could confirm that it also works for JIRA cloud version. My only recommendation would be to use Roles instead of Groups as a matter of organization.
Let me know if this information helps, Eitan.
