Hi Team,
I have Two Workflows in my project and Two Issue types.
Workflow : Testing and Production
Issue types are : Change and Release
Change issue type and related workflow is"Testing" Workflow and its status
ToDo ---> Inprogress ----> Collect Info ---- > On Hold ----> Move to Development ----->
Testing ----------->Done
Release issuetype and related workflow is "Production" and its status
ToDo ---> InProgress ---> Done
1) Now When i Create a issue with issue type "Change" and If i move the issue status from "In progress to Collect Info" a linked issue will Create automatically with issue type "Release"
and here If that Linked issue status is "Done" then the Main issue status has to change automatically to "Move Development" status.
2) And now if i Move the Change issue status from "Move Development to Testing " a another linked issue will create automatically with same "Release" issue type.
now If that linked issue is "Done" then the main issue"Change" has to move to "Done" status automatically.
can anyone please suggest me how to achieve this by using groovy script postfunction
Kumar
There's a lot of existing questions and answers on the Community that should help you piece this together. Without being in your instance, it's difficult to give you exact code, but these sources should help you out:
https://community.atlassian.com/t5/Jira-questions/Groovy-to-create-issues/qaq-p/818025
